Ratbag
- Joined
- Jan 1, 2012
- Messages
- 7,518
- Location
- Bayside, Melbourne, Vic
- Car Year
- MY06, MY10
- Car Model
- Forester SG & SH
- Transmission
- 5MT/DR & 4EAT Sports
Gidday Folks
As mentioned here:
https://www.offroadsubarus.com/showthread.php?t=5896
I ordered a cheap, knock-off Bluetooth scanner to use in both our cars.
This one arrived on Christmas Eve:
https://www.banggood.com/V2_1-Super-Mini-ELM327-Bluetooth-OBD2-Scanne-CAN-BUS-Supports-p-951062.html
This reader from Banggood cost AUD$11.83 total, including the AUD$1.60 airmail postage, and appears to work properly in both our SG (series II) and SH (series I). The former is straight OBDII, and I understand that the latter is OBDII and CAN-BUS, so the cars are slightly different from each other.
This company sells a lot of these that all look very similar to each other, but are subtly different. The above one is v.2.1 of their product, and supports both OBDII and OBDII over CAN-BUS.
I downloaded the Torque Pro (free) s/w from Google Play Store and installed it on my tablet. The initial Bluetooth pairing and working went quickly and easily. Apart from the fact that nowhere is it mentioned that the dongle's Bluetooth pairing code is "1234". I worked this out, after trying the other common code, "0000" ...
After removing and refitting the dongle, there was some kind of problem with the communication between the dongle and the tablet. It appears that I had not quite fully inserted the dongle into the OBDII socket in the SG. The SG has a shroud around the socket that makes fitting and removing the dongle difficult - think in terms of large needle-nose pliers!
The plug in the SH is not shrouded, but quite exposed, so it is very easy to remove and re-fit. Maybe I'll just lash out and buy a dedicated dongle for it. At this price, it's hardly even worth the hassle of removing the dongle from the SG once more ...
I should mention that this dongle fits completely within the shrouded hole in the SG steering column cover. So completely that one needs the abovementioned needle nose pliers to remove it!
Secondly, do NOT use the bundled s/w. My anti-virus s/w had a conniption fit even thinking about looking at it!
Besides, Torque Pro (free) does most things, and I will spring the AUD$4.95 to buy the full version.
Having a scan tool permanently installed in both cars at a cost of less than $30, delivered, is very enticing ... :iconwink:
The Torque Pro s/w is not very intuitive initially, but once one realises that one needs to press and hold the screen to add or move/delete items, it is easy to use. Some items offer both a dial or display, but do not necessarily work well if the wrong type is selected - e.g. Litres/100 Kms only works as a display, not as a dial - etc.
There are 7 pages of screens available to be set up as one desires.
Fault codes are accessed via the s/w menu system. It will display Logged faults, Pending faults and Historic faults, and gives the option to clear logged fault(s).
Some items (e.g. ambient temperature) work in the SH, but not in the SG. Both have ambient temperature displays in the dash, so a bit strange.
I will add anything else I think of as I go along ...
As mentioned here:
