Havent had time to read it all but this exerpt is good from above link:
"When the DCCD is in the lock setting and the front tries are on a slick surface(ice, grass, dirt, gravel, etc.) and the rear tires are on a high traction surface(tarmac, pavement, hardball, etc.) the amount of torque required to spin the front wheels wil be much less than the amount of torque required to spin the rear wheels. When the front tires start to spin the DCCD will sense the loss of traction and send all torque(minus what is needed in the front tires) to the rear tires to maintain positive traction. Once the car starts to move forward and the front tires move onto the tarmac and the rear tires move onto ice the DCCD will compensate again by transferring the torque to the front wheels.
When the DCCD is set to lock the front and rear wheels will rotate at the same speed, meaning that even though the rear wheels have more traction than the fronts and the rear wheels will get the majority of the torque the front wheels wil rotate at the same speed as the rears. Because of this function of the DCCD you may sometimes experience loud noises coming from the diff. For example, if the DCCD is set to lock and you are on tarmac making a sharp turn without a loss of traction you will experience clunking. Since the front wheels will be traveling a longer distance than the rears and the center diff makes the wheels rotate the same amount you will experience the clunking and popping of the center diff."
