jason tincey
anyone..........i cant drop the diff..
Jason, I used a stud puller socket (I think thats what it's called)i tryed today to drop the rear diff i un did the nuts but the bolt wouldn't come out, can anyone help?
I'd be in that.look the eaisest sollution is to just pop on over to Sydney and have Damo do it for you.![]()
thanks. just to be clear i have to force or the studs to drop the diff then to get it back in a have to force the studs back in with a hammer or something?
jason
Ok then, as I said in an earlier post, If you undo the 2 nuts & take the 2 bolts out from the diff that hold it into the sub frame, you will have more room to pop it back into place. In doing this the diff will hang a little lower with the axels resting on the exhaust pipe.
I just popped the rear breather cap off & drilled it out. It is either 8mm or 9mm
I then used some tubing with the same outside diameter & jammed it in untill it was about half way into the breather cap.
Then the tricky part...trying to get the breather cap back into the diff.
Just persevere with it, it just pushesback in (does not screw in)
Once this is done, just run the tubing to wherever you want to.
I ran mine up into the RHS strut cavity via the existing hole in the floor (on RHS of spare wheel well) & up into the rear quarter panel.
I hope that with the included pics, it now makes more sense.
Front breathers are easy - on my auto there are 2 short breather tubes on the "bell housing"; just get longer tubing and extend them up to the firewall; allow for a small loop at the end and then plug on a cheap paper fuel filter to keep the dust out. The manual is a different set-up; breathes through the dipstick I believe.
Yes that's correct. :iconwink:The manual is a different set-up; breathes through the dipstick I believe.
Through the dipstick?
Would have thought that dipstick was to sump, and the diff was a completely different oil reservoir .
I must get myself a CD of the service manual.
I agree strongly with this. Spent about two hours trying to do it and gave up because I have to be somewhere.
especially with the tube now in it.
But once I took the bolts out & let the diff hang down a little, it was a lot lot easier. :iconwink: :ebiggrin:
