Beachworm
- Oct 16, 2017
- 502
- Brisbane Australia
- 2010
- Forester X Luxury, sump guard, bigger AT tyres and 50mm Subieliftoz lift, breather extensions
- Auto
I've come across a bit of a problem that I would appreciate some advice on.
I have a 50mm lift kit installed in my SH Forester. I'm one of those strange people that likes to keep modifications strictly legal and I live in QLD where it seems to be harder than anywhere else to do that.
I have been doing a lot of research, communicating with Transport and Main Roads and consulting with 2 engineers they recommended and I have found out the following:
1. The Code of Practice for modifying light vehicles in regard to lifts other than using springs/struts/shocks does not cover unibody vehicles with ESC. This means that: a) If I want to lift my Forester to the 75mm limit permitted under the code I have to use springs/shocks/struts in combination with a 50mm increase in tyre diameter.
b) If I want to use strut-top spacers such as I already have installed I have to make application to TMR for their specific approval to go to 50mm and then I am not permitted to increase the tyre size.
OR use the services of an engineer to get approval for a high lift.
I am planning on applying for approval to TMR for the strut-top lift in the first instance and if that doesn't pan out I'll try a spring lift. I am aware that most comments on this site say a spring lift is not a good option.
What is your advice?
