• syncro and slashguard - pls logon and fix your email addresses
Hello, from the desert southwest.
scalman
Lithuania
2006 3.0R 5EAT Sportshift VDC/VTD LPG
5eat Sportshift
Nice. What kind solar panel there and what power it has , is it enough?
Long trips are best,If you can afford them
Hotfoodonaplate
New Member
Tucson, AZ
Forester L
Manual 5
I have a portable 100 watt panel. With a yellowtop agm. Also I have two 50 ah slow generator. That I can charge with solar or with either inverters that I have on board
Hotfoodonaplate
New Member
Tucson, AZ
Forester L
Manual 5
And it's enough to run my electronics and my 12 volt 45 quart Whytner freezer,.
scalman
Lithuania
5eat Sportshift
Allways wondered could it be possible like run some heater if cold or smt from that solar battery
Could that solar charge like second battery same as in car or main car battery ?
Hotfoodonaplate
New Member
Tucson, AZ
Forester L
Manual 5
Well if it gets too cold. I just run the motor for like ten minutes. That does the trick.
scalman
Lithuania
5eat Sportshift
so you sleep all ways in that tent ? warm weather ? so from extra battery only fridge coller runs ? but it could charge your main battery if it would need ?
