Door Trims.
silver
Tathra, Far South Coast, NSW
Manual
Much drama to remove the front door trims? I've got annoying 'rattles' coming from the drivers side trim and want to pull it off and see whats going on.
Have you a forester?
If so, dead easy.
Going from memory here. In the arm rest where you place your hand to close the door, there is one screw to remove. Then work your way around the edges and pull the trim away.
That's it.:cool:
These may help and provide a clearer picture.
:D Now thats why this site is so good!!
Don't have a 'clip remover' so gentle force will have to do.
Make sure that you put the window down before you remove and install the door trim,. It makes taking the trim off easier.
