  #1
Unread 13th July 2017, 10:05 AM
GreenSuby GreenSuby is online now
Year: 2004
Transmission: Manual
GreenSuby is on a distinguished road
Default Tripot cv removal
Gday all
I need to remove the tripot cv joint from the gearbox.
Does that just pry out of the gearbox/diff? The workshop manual i have shows a circlip on the inner end of the tripot.
Thanks
Greensuby
  #2
Unread 13th July 2017, 10:25 AM
jf1sf5's Avatar
jf1sf5 jf1sf5 is online now
Depends on the axle model. SF and very early SG are female with a pin, later SG and onwards are male with a inner circlip (the one you probably have).
It should come out of the gearbox quite easily but if not, dont pull on the axle but use a crowbar.
Subversive...
  #3
Unread 13th July 2017, 10:33 AM
Year: 2004
So the circlip doesn't actually hold the joint into the gearbox/diff?
Greensuby
  #4
Unread 13th July 2017, 01:55 PM
jf1sf5's Avatar
Greensuby
Yes, it does, but not rock solid.
Subversive...
  #5
Unread 14th July 2017, 05:06 AM
Year: 2004
Thanks jf1sf5
Got them off with a bit of leverage
How good is this forum when you can get help from the other side of the world!
Greensuby
  #6
Unread 17th July 2017, 03:42 AM
NachaLuva's Avatar
I'm guessing you have an SG Forester? When you lever it out, use a prybar up against the bolt on the gearbox, not the gearbox casing as that can crack
