  #1
Unread 6th April 2016, 12:46 AM
Taroona's Avatar
Taroona Taroona is offline
Year: 2015
Model: Forester 2.5L CVT Spec Edition
Transmission: CVT and 50mm SUBIELIFTOZ
Taroona is on a distinguished road
Default Diff breathers
I spoke to Subaru Aust today and they said
"Hey Les, the diffs do have breathers, which are located at the top of the diff housing, therefore won't be much higher than the diff itself.
It's not recommended to drive through water deeper than the lowest part of the suspension/lowest point of the wheel rim."
So does anybody know the exact height of the breather or is just a plug which can be extended.
Not that I want to go deep in water, but would like to know that if I should enter some water that may end up at sill depth or deeper because a wheel has dropped into a hole that I didn't know about that no water will be drawn into the diff.
Forester MY15 2.5L CVT
Special Edition 50mm lift
  #2
Unread 6th April 2016, 03:09 AM
bakerboy's Avatar
bakerboy bakerboy is offline
Year: 1989
Model: Pajero
Transmission: Manual
bakerboy is on a distinguished road
The hotter the diff, and the colder the water the greater the chance the air in the diff will "shrink" and draw in from outside of the diff, unless you've done a heap of driving and plunge straight into an icy cold river it is unlikely it will pull in any decent amount of water that will cause damage IMO
  #3
Unread 6th April 2016, 03:19 AM
Taroona's Avatar
Year: 2015
Thanks but I know that, thats why I was asking the question about how high it is and how the diff breather can be raised in a MY15
  #4
Unread 6th April 2016, 03:59 AM
duncanm's Avatar
duncanm duncanm is offline
Year: 1998
Transmission: 5MT DR
'how high is it' ? - near the top of your diff & gearbox.
'how high do I want it'? - how long is a piece of string? As high as your air intake is probably ok.
http://www.offroadsubarus.com/showth...hp?t=40&page=6
TT Outback
  #5
Unread 6th April 2016, 04:28 AM
Taroona's Avatar
Year: 2015
Thanks for the link Duncan, I had already read that. The reason I posted because there were non there relating to the 14+ models and was wondering if there was anything different for the newer models.
So thats fine I'll go and see scorpion at capalaba and see what they can do for me.
  #6
Unread 6th April 2016, 04:48 AM
duncanm's Avatar
Year: 1998
I don't know for sure, but I don't see why there'd be anything different with the way Subaru approached their gearbox/diff venting in recent models vs. the way they (and most manufacturers) have done it since year zero.
The vents are as high as practicable on the gearbox and diff.
How high you want it depends on how deep you want to go
Note that subaru's warning about depth not exceeding the lower portion of the rim is probably to do with wheel bearings and exposed greased joints more than breathers.
"lowest point of the wheel rim" is only 135mm assuming 225/60 tyres !
TT Outback
  #7
Unread 6th April 2016, 06:54 AM
bakerboy's Avatar
Year: 1989
Model: Pajero
My point was that stock breather location is fine, and going through a river that's deeper than the breather would still be fine as it is not likely to rush into it due to the nature of the stock breathers, I would go through water well over the diffs in my 4wd on stock breathers with no water ingression
  #8
Unread 6th April 2016, 06:01 PM
I'd extend them; I have on both cars. I certainly know of Subies and "proper" 4WDs that have taken in water in their diffs with stock breathers. Of course live axle 4WDs are more at risk as there are more places where water could be drawn past seals when things are hot.
MY'97 Outback RIP
  #9
Unread 6th April 2016, 08:23 PM
Taroona's Avatar
Year: 2015
Thanks everyone for your input, appreciated
In the past in "proper 4WD" I have only been in creeks up to the top of the wheels i.e. Patrol and Pajero and with this "car" I wont be going that deep probably only to the sill.
But I need to be prepared and informed of what I can and can't do.
  #10
Unread 7th April 2016, 10:44 AM
subyroo's Avatar
subyroo subyroo is offline
Senior Member
subyroo is on a distinguished road
Also be prepared for the sudden drop into a unforeseen hole.
Peter
2016 Honda CR-V
