  #411
Unread 4th November 2017, 02:24 PM
Rally's Avatar
Rally Rally is offline
Year: 2004
It’s a Harrop e-locker diff centre.
SG turbo, 99 WRX, PX2 Ranger
  #412
Unread 4th November 2017, 02:51 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
And it normally fits what 4x4 ? Nissan Terrano ?
Subversive...
  #413
Unread 4th November 2017, 02:56 PM
Rally's Avatar
Year: 2004
Nissan Navara
  #414
Unread 4th November 2017, 03:02 PM
Rally's Avatar
Year: 2004
Our recent trips off road with the car was with the interim R180 helical rear diff. We discovered that while the plated R160 had it’s limitations, it works better off road than the factory helical R180.
  #415
Unread 5th November 2017, 09:27 AM
jf1sf5's Avatar
Which Elocker part number ?
A11120 or A11250 ? Are the 27 splines compatible with the r180 27 splines axles ?
I think it should work out...you will have to build some more and sell them !
Subversive...
  #416
Unread 5th November 2017, 10:45 AM
Rally's Avatar
Year: 2004
Not sure about the part number. The Subaru axles fit into the diff centre. Main problem is axle retention and possibly length.
  #417
Unread 17th November 2017, 06:51 AM
Rally's Avatar
Year: 2004
Work has now begun of getting the e-locker into the rear diff centre. As you can see, we now have been able t do this. Next step is getting the axles to fit properly.
  #418
Unread 17th November 2017, 12:17 PM
jf1sf5's Avatar
Nice !
Is the crown a direct swap without mods ?
You had to use the grinder to take some metal off of the housing only to make the locker fit ?
Will you mahine some grooves in the diff splines to fit the axles, like oem ?
Subversive...
  #419
Unread 17th November 2017, 02:27 PM
Rally's Avatar
Year: 2004
Yes, yes, not known.
  #420
Unread 17th November 2017, 05:32 PM
El_Freddo's Avatar
Year: 1988
Model: EJ22'd L series
Nice work Rally!
So what's the flat metal plate connected to? I'm guessing it's just floating since it's the electromagnetic plate stopper.
I hope you get a solution sorted for the driveshafts. Always the biggest hurdle.
