Go Back   OFFROADSUBARUS.COM > Technical Forums > Under the Bonnet/Hood
  #1
Unread 7th July 2018, 02:20 AM
Brownie Brownie is offline
Year: 2005
Transmission: Manual
Brownie is on a distinguished road
Default Got a bad oil leak
Hi guys,
I recently bought an MY06 manual forester and I love it. But I noticed I was going through 1L of oil for every 1,000km as well as a burnt tire smell from the engine. No smoke out the exhaust, no oil in the radiator fluid and no oil left on the ground (that I could tell) but the passenger side of my engine is coated in oil. It looks like most of it is coming from the centre bolt of the rocker cover gasket but the other spot that look like there has been leakage is an on one. About 15mm back from the rocker cover gasket there is a round Rubber component in the head with a couple of allen key bolts. I don't know what this is or what seal it appears to be. I can even properly tell where it leads or ends. I have some photos which I will attach
I want to know what this is and whether it could be a source of a leak. Thankyou all in advance for the help!
The first image is of my passenger side rocker cover. The second is of that odd spot I mentioned. It is on the rear of the engine
http://s32.photobucket.com/user/Nich...g.html?filters
  #2
Unread 7th July 2018, 02:26 AM
Rally's Avatar
Rally Rally is offline
Year: 2004
Pictures didn’t come out. Hopefully not a head gasket. If you haven’t already done so, degrease engine then take photos of oil leak
  #3
Unread 7th July 2018, 02:30 AM
Year: 2005
Yeah, still having issues with the images but I think I've managed to fix it for now (kind of). The head gasket is clean as a whistle and there is a tonne of oil in the sparkplug tubes so the rocker gasket is a job that is definitely getting done. But this other spot makes me a bit nervous since I don't know what it is or does
  #4
Unread 7th July 2018, 02:35 AM
Rally's Avatar
Year: 2004
Is it a turbo or non turbo engine?
  #5
Unread 7th July 2018, 10:09 AM
Ben Up North's Avatar
can only hope to improve
Year: 2004 | 1992
Transmission: 5MT D/R | 4EAT
Sounds very similar to the oil leak my MYO5 has developed, no need in my case to add oil as yet (2500kms after llast service or theraebouts).
taking it into the mechanic on monday for an evaluataion. cleaned everything i could get to, haven;t found the particular area yet where it's coming from, but definately some coming from the same spot you mentioned.
  #6
Unread 8th July 2018, 07:13 PM
Year: 2005
It's a non-turbo
